Travel With Full Water Tanks
paulie484
200
49
Perth WA
quick question - heading off in a few hours to Exmouth and then Coral Bay
Coral Bay doesn't have drinking water to vans so need to either top up at Exmouth - pain to do at visitor centre, stop etc? or travel with full tanks - have got two tanks on a 17.56.1
read a bit that full tanks help with weight distribution ?
Van is loaded up with 2 weeks worth of usual crap that never get's used or eaten or drunken so extra weight is prob not a issue !
cheers guys
Glen Bundesen
336
212
Perth WA
If worried about weight, I'd fill up at Exmouth. I keep a 3 mtr hose for such activity.
Wikicamps indicates that there is a freshwater tap at 4 Learmonth st Exmouth as well as the Tourist Centre.
Reactions: paulie484
Holden_man
1,407
341
Brisbane - Carindale
cheers guys
Hi @paulie484 ,
Being a bit of a novice at towing I went to a Towing Safety Seminar at the Brissy caravan show last year, they also recommended travelling with full water tanks when possible to help keep the centre of gravity low. Guess that can only work so often, can't have tanks full all the time. Don't expect it's massively important but even if it makes things a little safer it's probably worth it and it does makes sense when possible.
HM
Pace
2,053
1,352
melbourne
cheers guys
Wouldn't worry re weight distribution as long as you put equal amounts in both tanks. As water is used, switch between tanks to equalise weight either side of the axles.
I just got back from coastal trip and went there with rear tank only full (to take weight of the ball, all ways experimenting l am!!), and in our case towed better full then empty (yes factors of internal storage positioning is a factor too).
So to give an answer, I'd fill up the tanks, better to have than to not have water. Pace.
Bmhdg76
769
516
North Lakes, Qld.
When we free camp I fill both tanks and can tell... Not just with the weight but the van "feels" more settled behind the car. When using the water though, I always use the tank behind the axle first. Found when I use the front tank the van is more prone to a bit of movement.
BJ
Swerve
282
484
I travel with full tanks, would rather have the water available should I need it, then not. I have a 20 litre on my rear 4wd bar and that also has been a god send.
