Towing
les2476
87
10
NSW
Hi guys just a question on towing heights. I have a ford territory 07 model and I'm wondering if I'm going to run into problems towing an outback flamingo. Has anyone had experience with this combo?
kyoshofw05
83
Hillside 3037
I used to have a 06 territory and was towing my 14.44.4. l have to say it towed it pretty well ( likes the fuel also )
my van tares at 1450kg l think. l used to love the car, all l can say is check the bushes every one and then.
hope it helps.
AdJo
10
52
G'day kyoshofw05. I see you tow your 14.44-4 with an AU series ll. We are looking at towing a 16.49-4 on road which is 120kg heavier with an AU series 1 wagon and was wondering how your car copes?
boots33
708
679
I tow an OB 14.44-4 with an 07 territory, plenty of get up and go but as Kyosh says it likes a drink too!
You can buy different height tongues for your vehicle so you should have no problems getting your height right. I don't know if the ball height on jayco campers is as woeful as it is on the OB expanders but you can see in the photo how low i had to go to get it to sit level. I have tried a few local places to get the ball height lifted on the van but none of them were willing to move it.
Soaring
998
1,249
Melbourne - Eltham
Just a couple of points to be aware of for towing on the pre 2012 Territories.
Engine cooling. Their cooling system is adequate for general use, but for extended towing and very hot weather it is important to make sure there is nothing resticting airflow into the radiator. for example the standard size vic number plate hangs down into the grill opening. I would recomomend either folding the lower section of the plate, or getting a slim line plate.
The shadecloth screens that so many peopel have reduces airflow significantly. If you are in an area that does not have a locust plague. get rid of it! You may think these two things would have a negligable effect, but I have seen the cooling system airflow simulations, and it is significant.
The other thing is transmission. The old 4 speed is a very strong aussie built trans, but nothing kills a trand like heat. An aftermarket trans cooler is VERY good insurance.
Reactions: Xpandafan
Brad
2,645
723
Rowville, Victoria
Boots why don't you get the jayco spacer I have seen some other guys use to raise the ball height on the van?
kyoshofw05
83
Hillside 3037
Hi Adjo, believe it the au is pretty good on towing. All l done extra was bigger trans cooler, disconnected from the radiator and heaver rear springs. the only reason l'll sell it if l buy a 4x4. Oh and on gas. Around town l leave it in 3 and once on a flat road l put it drive, l sit on the limit also.
3,060
2,345
My mate use to tow his Swan OB with his wifes Territory (petrol) with standard towbar, he could have done with a WDH hitch or at least airbags as the Terri use to drag it butt a bit but think that was more due to his loading in the rear, Yep plenty of power but as said likes to drink
They now tow it with his Pajero.
boots33
708
679
Have tried both the Local Jayco dealers including the same one that fitted chartrocks spacer but they will no longer do the modification. I think jayco head office may have put a stop to the practise. not really wanting to make up my own due to the possible insurance ramifications.
Brad
2,645
723
Rowville, Victoria
Was the spacer a factory accessory?
I thought it was an accessory that came from Canberra Jayco.
boots33
708
679
The spacer was an attempt by some dealers to help OB owners get some realistic height for their tow ball. It was never a mod sanctioned by jayco. The dealers got the spacers made locally, some like chartrocks used a solid 50mm chunk of steel and others opted for 50mm box with supports inside. Some dealers may still offer it to help their customers but unfortunately not around here. :(
There is an old thread here on the subject.
les2476
87
10
NSW
Does it matter if the van does not sit perfectly straight/level while towing? I have a standard tow ball and from the pictures shown mine would have to sit higher at the front.
Xpandafan
Seriously Likeable!
Aug 24, 2012
1,711
648
Kealba, Victoria
It's important to get it as level as possible Les. Certainly not higher at the front. There are adjustable hitch tongues available that should help you. If you don't have a receiver type tow bar fitted, I'd be investing in one as a priority.
les2476
87
10
NSW
I guess I wont know untill I pick the van up.
