Does anyone know where I can get a extended socket that will fit in a 12/18V drill and fit the stableliser leg nuts. Getting tired of using the hand winder and thought I'd use a drill. Thanks DOS
If you get a 1/4" drive extension it will fit in your drill chuck if a 3/8th doesn't with the appropriate size socket on the end welded together......... I carry a rattle gun for spinning off wheel nuts and will often use it on the legs, albiet gently.
