Ss-ss's 14.44-4
Ss--ss
103
129
Hills district, Sydney
G'day just added a reverse camera.. Got it from ebay & takes 3 inputs.. I never liked the prado reverse camera as it doesn't have a view of the towbar.. This I put in does & the other is on the back of the 14.44-4 .. Heres some photos
Reactions: ShaneT
ShaneT
291
308
W.A
like the camera, is the curled up black cable the AV lead? Do you have any links to where you got it from?
Ss--ss
103
129
Reactions: skippy
Bmhdg76
769
516
North Lakes, Qld.
Hi @Ss--ss
Are you able to take pics of your full install of the camera?
I have the same model van and am wanting to do this as well so am curious as to how you ran it along the van and up into the bunk area keeping it looking neat.
BJ
Ss--ss
103
129
Hi bmhdg76
If you see the pic above of the inside back wall what I basically did was drill a hole (with a step drill bit)at the height of the top bunk mattress so it would be hidden away.. The back wall is solid with insulation, I read other models ran cables from inside wall cavity but the 14.44-4 is filled with insulation... From there the cable runs to the top bunk storage where I drilled another hole , then through to the wardrobe.. From there just followed down the holes jayco already had to the floor.. Once through the floor followed other cables & through the chassis rail & out the rubber grommet.. Filled all the holes with sikaflex & cable tied ..
Bit hard to explain but that's how I did it, best to start from the back & work forward. Everything came in the kit except the bracket on the drawbar I had to make from a computer rack mount ear.. Here's a few more photos.. Hope it helps.
MDS69
733
803
are those shelves in your wardrobe home made or factory. Also what are the water pipes passing through the wardrobe for.
Like your work on the reverse camera.
MDS69
733
803
that's a strange one, they must have changed it. Our HWS is under the front dining seat with all pipe work under the van and the pipes pop up in the rear boot with the hatch near the number plate. Were the factory shelves an option or standard.
ShaneT
291
308
W.A
cheers for that, never new you could get them. I have been keeping an eye out for a nice plug to wire up my self but will go with that cable setup now.
