Special tool required
DaveS
215
183
Hi all
I claimed a damaged fiama awning from work and want to shorten it to fit across the back of my van over the door, basically cut 3 metres off it, it won't roll out as far but will be enough for shelter over the door.....
anyway it's all pretty straight forward except for the internal sprung arms, i've got the springs out and plan to just shorten the cable and then reinstall them ..... but
fiama must have a special tool like a 6mm nut on the end of a cable to pull the spring tight and click it into a locking tab ....... so
does anybody know where i can find/buy a 6mm nut that can be crimped onto a cable end, so i can pull the spring back into place has to be a small diameter to fit thru a hole ?
Reactions: blacky
DaveS
215
183
thanks guys
sorted it out .... welded a 6mm nut onto some rod, welded a T handle on the other end, screwed this onto the thread on the end of the fiama cable and pulled it into place pretty easy (well 10 pulls did it till i managed to click it into place).
so i've shortened the arms from 1300mm to 700mm so the awning will only go out about 1.5m, but thats enough for a rain shelter over the door :)
bloody blokes at work paying me out about how pimped the old van is now .... gotta luv it :) she's a rare old van and always draws a bit of attention with the stuff added to her :)
Reactions: Antman
cruza driver
Hercules
6,551
4,449
Mighty Victoria
Good work, if I'm picturing it right I saw a slip on camper on the weekend with a modded awning with shorter arms.
By the way I think its time to start a thread on about your van :boink:
Reactions: bigman0510
DaveS
215
183
yeah i've got a few snaps of the old girl i'll do a post this weekend
fiamma do make a short awning to go across a van, but they only come out 700mm i'm hoping to double that
