Solar Controller
Aug 29, 2012
12
21
Lysterfield Vic
Just wondering if anyone can help just pickup up our new 20:63.1Ob this week, I have been out playing around with the solar controller we have 2 x 120 watt panels and a TPS555 controller, it has a 3 stage button #1 is battery volts, #2 is amps from solar panels, #3 is amps being used, it shows the voltage @ 12.7 but stage 2 and 3 display 00.0A nothing, is there something I am not doing correct should they display amps in and out?
rodney
136
117
42
Battery is full so won't put any in the usage sounds like it may be picked up wrong possibly
createit
41
62
I have found the same on my 2 week old 17.56-2 with 2 x 120w panels as well. I have only had a full battery and it is now under the carport and haven't been able to check the full charge theory. So please keep us updated with what you find as I may be in the same boat. Do you have a drifter control panel as well? I have been told to make sure the battery switch is turned on in the drifter panel and the main isolator as well.
rodney
136
117
42
To see if there is a draw the switch needs to be on however no need to leave it on when it has solar if concerned can switch on for traveling for a charge from the car however I leave mine off and let the solar do the job when plugged I to power the setec charges the battery so I only ever have it one when in free camp
