Slow Drain ? = No More
Sterlo1
31
5
Narellan Vale, NSW
Decided to simplifly the drain outlet and got carried away. Ended up replacing main pipework as well as the outlet. I used 40mm Pressure fittings and matched it up to 40mm smooth bore sullage hose.
Before and after Photos. The washing machine outlet remains unchanged, however Jayco service altered the outlet on the first sevice as it was behind the drop down leg.
Cheers, Paul.
Ch00ka77
184
80
Maffra VIC
Yeh looks good we are going to do the same and am thinking of re-running the piping and enclosing all pipe work and wiring with a sheet of Teflon or nylon to protect the undercarriage from damage.
Glenn
103
4
Bittern, VIC
Hi Sterlo,
Good to see hoe youv'e made the mod's so that when we Finally pick ours up i will be able to make similar alterations.
Cheers Glenn
