Setec question
smwilk
29
Gold Coast
I've had my AC mains plugged in for 24 hrs. Battery switch is on! Voltage is showing no more than 12.55V. The manual says these charge at above 13v and 14v for float. Is there something wrong with my Setec 35II?? Could be in trickle mode but what voltage should that be??. Thx
coled1970
374
308
Hunter Valley, Newcastle
Check the light at the front is not on (Fault). Check to make sure the setec is plug in and turned on as i have done so myself and wondered why it wasn't charging. With the 240 plugged in when the main switch is turned on you should hear the setec kick in. Check your main fuse.
Chooky
356
462
Glenden, Qld
Make sure the setec is actually turned on, it will be plugged into a power point close to the unit. We went for a couple of months in our old swan before we realised it was turned off.
