Just hit it with a hammer to smash the lens, should find 2 screws which hold it to the wall..
I like your subtle style
just buy a better outside light and smash the damn thing off, way easier.
I have security sensors also but mine has four legs and a tail!I am one of the many here who has installed a LED strip on the outside and almost never use the factory light. But after having some random drunk people thinking that it is funny to disturb things around the van then bang hard on the door in the middle of the night I am thinking of replacing factory light with sensor light. Just to add small bit of security
how on earth do you get this off??? Been trying for a while now and can't work it out!!
That's what I did. I had to remove the cover so,that I could install a 12v connector for my awning LED light strip.It's a prick of a thing , if I recall I used a scalpel to slice around the edge to cut the silastic then used a thin driver to push in the tabs which you find on either end, so holding both tabs in use your other hand to gently push/lever the mongrel thing off, 3 hands is helpful, now I think thats what I did, it was a gentle push here and there as I explored for hidden lock tabs........I was going to fit a led in it and use the power feed to supply my led strip outside but found the led was the wrong one and running a cable was not easy plastic was brittle, so just stuck it back and drilled a hole elsewhere for my led strip cable run...........
If it's a few years old just buy a better outside light and smash the damn thing off, way easier.
Might have done a post on it http://www.expandasdownunder.com/threads/drovers-14-44-3.4502/
