Rear Clearance light, bugga.
20,012
So I remove a side light, well an upper rear clearance light actually to run a cam cable, while cleaning up the silastic, approx half a tube squeezed in the hole I think, the bloody light drops and unplugs itself !!!!!!:( yep, the damn cable is still inside and I can't grab the ends...................:eek-53:...couldn't pull the rest down either, tried all sorts of wires, hooks and things, no luck, some blockage in the shute....looked at removing the cupboard inside to get access to run a new cable, :blue: after a look at things yuck give that a miss, one last ditch effort with a bit of No 8 fencing wire to force the issue....:cheer2:...not only got it down but managed to pull a new cable thru and :distracted:now all is working nicely again and the bloody new cam can sit on top of the tyre carrier like @chartrock , thought it would be easier to just stick it above the rear bed hatch than do some welding and painting.........................WRONG.........tomorrow the plan will come together..........:cool-19::cool-19::cool-19:.....insurance paid up......check.:biggrin-26::biggrin-26:
Don't touch those clearance lights! They normally break or the wire won't budge because it is siliconed in firm.
I thought I'd change the surrounds on mine because they had yellowed a bit and replacement chrome surround were $5 ea. back ones weren't to bad on mine but the front were terrible to do. Never again.
20,012
Since the prang, mine has got black on one side and the rest are white, they couldn't get white ones for a week or so, I wasn't waiting any longer black or silver will do I told them, I thought I would see which looked better then respray the others to match, black looked good so I went to pop a white one off, both tags just fell off with a hard stare so a dollop of silastic pushed stuck the light in and form one side I have white lights the other black and I don't care........................ I should have known better this time though.........gonna be fun when I put the alloy panel down the side, might just budget for new light frames as they will surely self destruct when I pull them off.
So where did you get the new surrounds from @macca ????
RV express online store. I think you can get white, black or chrome. I went chrome because I thought they might be more uv resistant. I have a couple new white surrounds at home. When I am back after this trip I will send you a photo.
Cheers Geoff
20,012
Will have a lookie, easier to buy new than spray paint, so much buggering around to get the right coverage, and at that price it's cheaper than the paint etc.
