Gooday all,
I`ve installed a dual battery system on our NT Paj (Projecta 150 kit)with a yellow top AGM as the extra batter. I`ve had this system working well for a while now and decided to add a feed to the rear of paj and Anderson plug to connect Expanda Dometic 2350 fridge for 12 volt operation whilst driving.
After reading various forum posts I purchased and installed a Projecta VSR 100 immediately off the 2nd battery.
The idea was that I could connect van fridge to Paj, and whilst the Paj was running and charging above the lower threshold of 12.8v, it would run the fridge, but once stopped, no 12 v to relay would disengage solenoid and prevent battery discharge and flattening.
I connected everything up as per instructions, but without the manual override, as I believed I wouldn`t need it for this application.I added one of those cute little Anderson covers with an LED to show power.
Turned on- no power to rear
No LED illumination
No LED illumination on relay
14.2v on supply side of relay- nothing out
Thinking the relay may be a bit tight or stick? I connected the manual override up as per instructions, switch LED illuminated OK but still no voltage downstream.
Next step was to jump across the main terminals, 14 volts at Anderson plug at the rear.
Just in case of wrong assembly I tried connecting the override lead to the other terminal of the VSR block, no change.
I contacted the supplier who was helpful, but said that the Projecta VSR wouldn`t do what I wanted, and I needed a continuously rated solenoid to do what I wanted.
The Dometic fridge specs show it draws 175 watts.
Can I do what I want to with what I have, is the Projecta not functioning, or have I just got hold of the wrong gear to do the job?
I`d value suggestions from anyone who has succeeded or failed with what I`m trying to do, I`m not a techno, but reasonable with a multimeter.
The only thing I can think of I may have done wrong is connecting 12v control wire to battery, and not to ignition, so may not be triggering cut in/out?
No LED illumination
