problem with door lock?
sledge
Banned
Feb 21, 2013
77
14
Sunbury
as mentioned in my previous thread I thought it worth while to start this as another thread to alert owners to an inherent problem with the door locks. sorry if it has been discussed before but as our van is less than 12 months old I thought wouldnt hurt to repeat for all to be weary.
my wife locked the van as you normally would and on return we couldnt get the key in. we tried for on 30 mins and no luck. we thought someone may have jammed something in there but this wasnt the case. we were fortunate that a neighbour lent us his son to enter through the storage bay but unfortunately it wouldnt budge from the inside.
so after no luck with jayco roadside got hold of the only locksmith in town who arrived aroung 6pm. he noted straight away that the lock slot was on the horizontal and should be on the vertical after a key has locked and been removed from the lock. so being in the horizontal position was why the key couldnt be reinserted. he did his magic, turned the key slot and pointed out that the keys werent that well cut at the top edge, so cut me 2 new keys and all was great.
all I can say was thank goodness he was available and we werent bush as the axe was looking pretty good in making an alternative entry :(
hamish22
742
641
West of Newcastle
www.grmotorsport.com.au
This is a real issue and has now happened to me twice.
Last time was when I got home from xmas holidays and the Wife locked the door but the key jammed in the horizontal position.
Luckily I have a rear door to get in and once I got the door open and barrel out I had to put it in the vice and tap the key out it jammed in that hard.
I have since been to Jayco and bought a new barrel which will be going in before our next trip!
Ren77
581
North Queensland
That's a good tip....how awful would it be when you are out in the middle of nowhere and not be able to get into your van? So it's a good idea to get some extra keys cut as soon as we get the new van then?
I try not to let anyone lock the van but me.
What I mean is I have told everyone that they have to be really careful with the way they use the lock and if I'm around I generally lock it otherwise my wife does, I try not to let the kids use the keys in the lock.
Navman
21
9
I believe that we were the "neighbours" on the weekend or by some strange coincidence the exact same thing occured :) There was no way that key was going back into that lock and the locksmith was brilliant. It does however make you wonder whether or not there should be a recall on these locks. We have also had trouble at time locking our van. Might be time for us to get some new keys cut too.
Bmhdg76
769
516
North Lakes, Qld.
Yes if there is that many people with the same issue then shouldn't something be being done? How could we get some action on this issue? We generally always free camp and is now my biggest fear in not being able to get in or worse still, one of the kids being locked in!
BJ
Brad
2,645
723
Rowville, Victoria
Another way to try and enter is to jack up one corner of your van which can twist the van enough to bypass the entire lock. The door will simply open. Well it did on my last van anyway. Haven't had to try on the 18.
Reactions: skippy
Navman
21
9
BJ
I agree. It would be a terrible feeling to be locked in but I think that as you don't lock from the inside with a key then the risk of this happening is a little less .......hopefully
straydingo
1,143
652
I had a few minor issues while away over Christmas break.
I remove the lower latch plate off the wall so there is nothing for the lower lock to engage to. No more problems
3,031
3,401
Just had this happen to us. We were in Forbes and i just exited the van and locked the door. Next thing I couldn't get in. No locksmiths around until the next day at the earliest and a $300 charge! Got to Parkes and the Windsor dealer who had some spares. Son crawled inside and screwed the lock apart so I could get it opened. Once opened its the barrel that was jamed. But to get the barrel out to replace it you need the pins aligned ie the key in!!! So knowing I had a replacement barrel available I belted the key in to align the pins. The key was still tight with a 1 mm to go. Once all home it came out and the barrel started working again! For the $40 I changed the barrel anyway but am convinced if this happens again it will just take a forceful "tap" to get the key home and all will come good? Hopefully the newer barrels are improved and it doesn't happen. They are a slighty different key.
Big thanks to Judy at Jayco Sydney for assisting with info over the phone, the service was excellent. She had organized Orange Jayco to have a spare waiting if we headed there.
Also the guys at Parkes Caravans were very helpful and carry a good range of spares so I was able to continue on .
3,031
3,401
Something else i have noticed is that out of the 2 sets of keys we have the door has now jammed numerous times with the one key only and not the other!
Hamish when this happened it did with my spare cut key! The other thing was I had just come off about 80km of dusty dirt road. Although the lock didn't show any signs of dust, but I had given it a drink of water followed by 3 squirts of WD by then to try and fix! Iam convinced the method above would work if it happens again. It's the same principal as a "bump" key but with all the pins perfect.
hamish22
742
641
West of Newcastle
Yeah I don't know if it is a coincidence that it has only been the one key, but the last time as i said in my first post the key was so jammed in the lock I had to tap it out with a hammer and its been fine ever since!
Like you I have since bought a new barrel and will replace it if it happens to jam again!
Swerve
282
484
Hmmm, Might need to install a internal access hatch to my locker, should I ever need to break in. Is there a way to tell if you have a good or bad barrel ?
donnybabes
41
16
Bendigo Vic
Im having problems with my lock too.I got locked out,the lock has jammed several times. Is there a replacement that can be got as I dont trust the lock anymore.I have had it looked at but its an intermitten thing with the jamming.
