might be a good move to check your state regulations on where you have any home lpg gas cylinders installed, ours have been in the same place for over 30 years ,but they dont conform to qld. exclusion zones, and placement near specified ignition points , all comes down to either move the van out of the carport or move the gas cylinders, apparently if they are not compliant there can be an issue over insurance coverage if the setup has been identified , ignition sources include power points,plugs,fridges,hot water,pumps ,fans, meter boxes, and anything else which has the potential to create a spark, even a battery sitting on the ground within 3.5 meters of a cylinder valve is a nonconformance and leads to an immediate stoppage of supply. gas tanker and bottle swap, best to look at your own state regs as they may differ
