No flush water
Hiluxpanda
135
30
After 2 days pod use the flush water has gone dry! We are connected to mains. Any ideas? We here does it feed from?
fishinglizard
216
130
West of Sydney East of Lithgow
mines got a filler above the waste tank the flush water goes in there, its not conected to the water tanks or the mains pressure tap. I have 17 55 disco so I assume its the same.
minute 1.14 on is the same I have
Xpandafan
Seriously Likeable!
Aug 24, 2012
1,711
648
Kealba, Victoria
Flush tank will last longer than the cassette takes to fill. Should make sure the flush tank is properly full by using the glass tube gauge, as the filler spout always appears full (which can trick new players). On the plus side you can refill flusher with water that is not suited for drinking and save your tank water.
