Jayco Outback 16.49-3 March 2013 model this is the list so far which has gone wrong with van and has only been out on 4 small local trips to perth.
Two new solid bed end covers both cracked and one also blistered
New dinette window seal fell out
Roof need completely re sealing as sealer was pealing off
Rust on chassis from where they done pipe fixing and hit with the drill chuck
4 new roof clamps as old ones going rusty from not being powder coated properly
Water brackets replaced due rust not galvanised properly
Bed frame needs repairing or replacing on front as coming apart waiting to here from dealer
Air conditioner cabinet switch on to test heat side and next morning cabinet delaminates
Lost 12 volt power two weeks after receiving van ,wire came out of brass connector in battery box
Trim on internal bed step needed trim putting on properly
Mattress problem where end is different height to centre mattress jayco would not fix
Trim on front of van needed new aluminium trim as too short and left hole in corner
Bed end leak through hinges both ends but luckily doesn't come in van
Jayco answer to these problems is that we will keep fixing the problems and give a year warranty on parts replace they are not interested in extended the warranty of the van or any compensation. It's a shame they don,t checked the vans as they come out of the factory as their quality control is shocking.
Cheers Smash
Cheers Smash
