OK so we have had the Expanda for nearly four weeks and have packed her up and done a few of the Mods others have done. We named her ELUNEKE using the first two letters of each of our childrens first names, except the first two as a double LL did not look right. The LEDS are in, thanks Jim and Tab. The sliding drawer is in the small cupboard. We put space saver coat hangers in the wardrobe which gives hanging space for about 40 tops (bought off E-Bay) The outdoor shower set up is a Primus 12V shower costing about $20 I think from Bunnings ( We used this shower on Fraser and worked really well plus it is alot cheaper than the one from jayco). My wife added the fire Blanket just in case, the last thing is the Do not overtake turning vehicle which is a must if you over 7m including the towing vehicle. this means you will not be at fault if you stray into the other lane when turning or going round a roundabout .View attachment 7389View attachment 7390View attachment 7391View attachment 7392View attachment 7393
We did however have one issue with the LEDs and that was a couple of them came away from the backing so if your lights are getting hot and you have LEDs then just check they are not touching the light cover. all fixed in a couple of seconds though.
