One is 50psi the other is 70psi and John Guest fittings and pipe are rated for cold water pressure of 174psi (1200kpa) so I think your safe, the HWS has it's own PRV on both sides, mains pressure is very, very rarely above 60 psi anyway.............unless the Firies get the line boosted. Big Mal is running one with the insides removed except for the restrictor which reduces the hole, found it works better, removing the whole unit the toilet flush didn't like the pressure, so for obvious reasons action needed to be taken.
