Mains water connection
billykidd
86
36
Has anyone found an improvement on the standard Jayco mains water connector ? Mine has turned into a nice water feature, with water coming out of where the hose connects to the van. Have tried a new washer, but suspect it is the plastic having the weight of the hose on it is too much, and the connection is now dodgy. I've the standard plastic version as per the image. The plastic fitting itself is about $2.00 plus freight, but then the problem is likely to repeat. I've a 12v pump connected to the tank, but would like to use the mains pressure for the sink, and front tap when we are in a park.
In our last van I moved the water connection to under the rear of the van near the drain. I then put the outside shower assembly in that location.
billykidd
86
36
thanks, suspected this was the best way to go, at least then I can use a quality fitting. Moving to the rear and adding another tap is an option that I've not thought of, even though it is only a 16' !
At least it gives me something to tinker on this weekend.
Reactions: Burnsy
cruza driver
Hercules
6,551
4,450
Mighty Victoria
I bought a brass fitting when at Longreach last year and it fits better than any of the well known plastic brand ones I tried. And no more leaks or drips.
Hi mate, just make sure your inlet goes to the pressure valve first so your plumbing is protected from high pressure. :)
meandher (a frost)
153
391
The Vines, WA
And I thought it was just a scabby connection on the supply hose I bought for the 'van, not realising that it is just the standard Jayco fare, most likely procured from the cheapest end of the supply chain monster that is possible. I am a relative newbie to the dragging your home behind you brigade but, come to think of it, I had the same issue with the old Swan Outback where we had the same ever expanding water ring of no confidence that would be present most of the time.
This stuff can't be rocket science to ensure that it is right from day one. If a $5 fitting will fix it, then Jayco should be aware of it and just rectify it from the factory as part of a continuous programme of customer satisfaction upgrades. These rigs, whilst not being the most expensive units on the market, aren't cheap and surely it is the small things that make a difference when it comes to Quality. The Expanda is a brilliant concept that is let down by poor factory perception of their buying public, bordering on arrogance. In the end though, we are all to blame for putting up with crap as we keep buying the bloody things knowing we are going to have to fix stuff. Dumb things like this on a Holden Commodore purchased for half the price of what we buy our rigs for, just would not be acceptable to us or the major manufacturers and we would all be banging on the GM Service Department door with a large pineapple to assist in the argument to have inherent faults fixed. I seriously doubt we would get the spanners out and jerry rig the vehicle that gets us to work and back, so why do we do it on our 'vans? This goes for issues that I have had with ours that all seem to strike a familiar chord with other owners on this site. Whether it is badly fitting internal doors and drawers, screws that hold things together being too short and too small a gauge and drop out on a regular basis, jockey wheel mounts that have been erroneously tack-welded by the one armed, blind apprentice with questionable trade skills. I could go on, but you all know another dozen or so inherent faults that seem to occur with monotonous regularity on these pages.
Jayco have hit on the holy grail of supply and demand. They supply what they want to and we, the buying public, don't demand enough when it comes to Quality.
I need a holiday -I am beginning to sound like my Dad :)
@gwadir , It is my old my jayco posts.
http://www.expandasdownunder.com/threads/macayaks-16-49-4-mods.2132/
I only had one tank so just cut a hole in the shower for the tank filler. We hardly used the tank so it was just filled there if needed. Worked ok for us and all the pipes were there so it made sense to put the shower there. I never liked the idea of the way the mains water is connected to Jayco's. I would do it with a new/old van but the inlet housing is under the slide out so not a good spot for a shower. The water inlet will be going down the back with the new drains.
jvp
106
40
69
Yorke Peninsula Copper coast SA
I agree with alan frost's comments. I'm in the automotive repair industry. A customer will complain over a finger smudge in some "who cares place" on some (H.O. SH T} but most of us spend hours to fix jayco design flaws over the years without question.
Anyway I still like my panda.
jvp
Wanda
336
291
I think I might like your Dad !!!
Reactions: mfexpanda
