Hi All,
Our old 17.58-1 OB went off to a lovely young family in Rockhampton in January and since December we have been patiently awaiting the arrival of it's replacement.
With our intention of setting off on an indefinite lap we reconsidered things that are must haves for full time life on the road rather than just making do for a month or so at a time, and the few big things that we couldn't work around with the 17.58 were, full sized fridge and freezer, built in shower and toilet, and main bed size. Some can be worked around but in the end the less you have to do each time you stop the more likely you will keep at it, well that's my theory anyway.
With this in mind we looked around at what would fit these new criteria but remain in our budget and weight tow capabilities. Given the great run we had with the 17.58 it was hard to go past Jayco although we did look at a few other makes.
In the end we settled for the 19ft Jayco Starcraft as if filled all the requirements pretty much perfectly, it was order on the 20th December 2017 with the following extra's added via the factory,
Extended drawbar
Center mount Jockey wheel
External Picnic Table
Grey water tank 60lt
600kg payload and suspension upgrade
2nd gas bayonet
Offside awning light
External shower
Upgraded solar to 2 x 160W panels
Offside sail track
2 x 100ah batteries
L Shaped dinette with MAPA table
Full Leather trim
Washing Machine
218lt Compressor Fridge Freezer
Larger front roof hatch 700x500
Privacy curtain across main bed
In the process Jayco changed model names and features to Journey from Starcraft, and we ended up getting some nice additions at no extra cost like, Tuff Frame constuction/Smooth walls, Ceramic dunny, J Panel control screen, Ibis 3 A/C, all up quite a few thousand $$$ saving as these were all $$ add on's in the MY17 range.
I have a couple of items I am adding in the coming weeks like, 12v fans, diesel heater, SOG dunny vent, AFK, Stonestomper and then we should be ready to hit the road hopefully before the end of May.
Extended drawbar
2nd gas bayonet
External shower
Offside sail track
2 x 100ah batteries
Full Leather trim
Washing Machine
