Got this email from Jayco today.
Interesting....
Jayco is proud to release the all new JTECH Suspension!
Precision manufactured using automotive processes to ensure exact fitment, JTECH Suspension is the product of two years' research and development at Jayco's Melbourne headquarters, and countless kilometers of real world testing across the best and worst of Australian second class roads.
The purpose designed JTECH Suspension complements the Jayco Endurance Chassis replacing beam axles with individual stub axles, allowing each wheel to react independently to the road surface, while also lessening the chassis' unsprung weight.
Delivering greater stability, a smoother ride, more precise handling and increased ground clearance without increased ride height, making towing easier and safer than ever before.
JTECH Suspension features include:
1. AL-KO stub axles, bearings and brakes that are suitable for fitment of AL-KO Electronic Stability Control
2. Electrocoated surfaces for optimum protection against corrosion and stone chips
3. Large diameter, heavy-duty Pedders off-road shock absorbers and coil springs designed specifically for Jayco RVs and Australian conditions
4. Aeon rubber springs inside each coil spring, producing a progressing rate when the suspension is compressed
5. Toe-in and toe-out adjustment for wheel alignment
Interesting....
