I had a problem with the Truma air conditioner last week. It has been working fine, but as you expect the day you hook the car up it decides to stop playing.
When I went to turn it on before leaving it would not turn on and showed a solid red LED in the remote sensor on the unit, and would just flash red 4 times when I pointed the remote to start it.
I did a manual start with a toothpick in the sensor and it showed the blue LED and appeared to start up ok and soon the compressor kicked in and it began to cool. After about 5 minutes it shut down again and when trying to prod it to start again, it would show the blue LED for a few seconds, kick in to life then stop.
There must be power to it as it still will do that when trying to manually start it, run for a second or two then stop with the solid red LED glowing.
I had a cover over the van and had not run the air conditioner for a couple of weeks. Would anybody have a clue as to what might have caused this?
