Yep get electrician to do 240v work... There are soooo many options and ways to setup... Talk to a good 12v power shop (sorry but can't help with contacts in BNE).
I installed a Projecta IP2000 inverter for the
option to run it through all GPOs on a van - one of many features it has is auto sensing to switch between 240v and 12v power supplies. I.e. It can be wired inline on the main incomer for direct pass-thru on 240v (it automatically switches to mains / pass-thru when when it detects 240v). When off the grid then flick the on button (from the remote control panel...) and it will draw 12v power then pump 240v inverted power down the vans power cables to get to all GPOs (you will need to disconnect the Seteks charging circuit tho). This brand and model of inverter specifies a Type A RCD be used in line - get a sparky to check the if existing RCD has a Type A profile and you'll have RC protection (I didn't bother pulling mine out but it looks like a std size RCD so changing it would be a piece a don't be rude...).
A) I didn't do the above because it was a PITA to pick up the main incoming 240v cable and run cables to the inverter which is mounted under the dinette seat... Jayco wiring is so tight to get into. And because I couldn't see the real need to run power thru to all sockets.
I like to control the power being drawn from the batteries when off the grid and running on solar - so I wired to only one GPO under the dinette and use an extension lead to the device (nespresso machine gets a work out). I don't have to worry about the setek as mines not wired to the whole 240v circuit.
Ligedy's 17.56-2 OB
Good luck with your solution, cheers ligedy.
