interesting post found
I found this post on another site I visit occasionally, and thought it may be helpful to someone.......
Tips & Tricks
Holiday Park Tips
  • Have a trial weekend in a nearby Holiday park so you get used to your new caravan.
  • On arriving at your destination after a long trip, do not panic to set everything up when you first arrive.
  • Park your van onsite and relax with a quiet cuppa or cold drink, take in the scenery, say "Hi" to your neighbour or give the kids a swim, then take your time setting everything up.
  • Remember you are on holidays, there is no rush.
Packing Tips
  • Checklist, make up your own checklist and tick off as you pack.
  • Analyse your checklist on your return and delete those items not required.
  • Spread your load evenly throughout the van, packing heavy items down low and close to the centre of the caravan over the axle.
  • Run your fridge for at least 24hrs prior to your trip to cool it down.
  • You will be surprised that with a little bit of care you will be able to reduce the load in your van considerably.
Towing Tips
  • If you are not familiar with towing a caravan then consider attending a towing clinic.
  • Be aware of the extra length and width when turning or over taking.
  • Always ensure you have fitted your towing mirrors to your car before leaving.
Reversing Tips
  • For safety always have someone watching from the rear when reversing.
  • Practice reversing in a local car park when it is quiet. Form a large circle using some buckets and practice reversing in an anti clockwise direction, this will allow better vision.
    When comfortable with this, try reversing clockwise.
  • If possible when reversing on to a site, approach the site to enable you to reverse in from the drivers side (anti-clockwise direction), this will give you a clearer vision of the side of the caravan and of the site, and will allow easier and correct positioning of caravan.
Driving Tips
  • Stop and refresh regularly on long trips and use this break to check to see that everything is in order in and around the caravan.
  • On your first trip, and its still good advice thereafter, to set off at a quiet time when traffic is at its minimum and just take it steady until you get the feel of towing.
  • If a road train or heavy vehicle is approaching from the rear, do not slow down to allow them to overtake as they will have already judged the distance and taken a line of approach. Just simply maintain your current speed and position, keeping to the left.
  • If traffic is building up behind you, pull over when safe to do so and allow them to overtake.
  • Consider purchasing a UHF Citizen Band (CB) radio. Heavy vehicles sit on channel 40 and will usually try calling you first before overtaking. When both the caravan-er and the trucker speak to each other it makes highway travel a lot less stressful and safer for all concerned.
