Looking at installing my washing machine in the Expanda 17.56-1 by the door on the left as you enter. Has anyone else done this before. If any one has, some pics would be greatly appreciated. Cheers
What's the water consumption like per load?
yeah "lots" worked out to be about 60litres per load, seems to fill the machine three times each with about 20 litres.
For us we will only be running it when connected to mains one because of the water usage "don't want to drain the tanks" and also we don't have a generator and I think we could run it off an inverter but would chew through the battery
And it worked a treat when tapped into the sprinkler system at El QuestroWhen we were travelling, we used a 600w pure sine wave inverter when free camping and had access to water. We also used the quick wash cycle that doesn't use as much as the normal cycle. From memory our machine is 230watt so no real drain on batteries as we used it during the day with the sun shining.
HAHA I must have imagined itDon't know what you're talking about....
