Hi all,
Just thought I'd update you on a very low cost, but very effective security system I found on ebay.
Its a GPS tracking unit, but it has quite a few more features that make it very useful as a caravan security device.
http://www.ebay.com.au/itm/271235658075?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Given on other posts on the forum about physical security, and the fact that most of them can still be removed, this device can sit silently and monitor your van, and then send you an SMS if it moves, giving you its exact location, and allowing you to see where it is on Google maps, see how fast it is going etc.
It also has an output for a siren, and can be used to trigger when the door is opened, so it both sends a text, but also sets of a siren. Great for leaving your van when free camping to know if someone has opened the door.
It was actually working with the GPS and 3G antennas inside, but just to ensure it has the best possible signal, I mounted the antenna's up on the roof.
It even has a remote control to arm and disarm the door alarm function, or you can sent it a command by text message to arm it remotely if you forget to press the button.
