Gas hose
Smirke
1,687
2,915
Palmyra, WA
am looking for a gas hose for the van so we can hook the bbq up to the outlet. Can't seem to find one with the screw on end one end and bayonet on the other . Anyone have any ideas where I can get one in perth?
@Smirke ..... Are you after one to fit a weber (Bayonet one end and 3/8" SAE) or a standard Bayonet to 3/8" BSP fitting?
If 3/8"BSP have an unused one here we could do a deal on ;)
(I ordered the wrong one for our weber) :oops:
Smirke
1,687
2,915
Palmyra, WA
Thanks @dagree . Hubby took off with the hose tonight, so I'm not sure what we need. We found one for a webber, but we have the neo buddy and they are different sizes apparently. We need one that has the bayonet one end (to fit the van connection) and a thread at the other to fit the neo buddy ( not sure if it's 3/8 or 3/7) will ask hubby when he returns. He was going to try burn back tomorrow. (They are just down the road and he uses them a lot for work).
Smirke
1,687
2,915
Palmyra, WA
He's back. Our bit on the bbq is smaller than the webber connecting bit.
Also, what is SAE and BSP?
SAE and BSP are the thread type/diameter/thread pitch etc on/in the fittings...... They look very similar but ensure you get the correct one as you don't want to strip the thread, or worse, have a permanent leak.
If you get stuck and need it the BSP one I have is yours..... Just got to get it to you somehow if you want it before Ledge Point.
Smirke
1,687
2,915
Palmyra, WA
Mr Google couldn't help. Went into rays and checked in theirs. We need the 1/4 end. Thanks for the offer @dagree . Hubby visiting burnback on way home this arvo to see if they will make us up one.
Hope you get it sorted before Coral Bay @Smirke
If you can't get one from Burnback any BBQ or Kleanheat store should stock them.
