My Dometic Fridge stopped working on 240 volt. Initially I wasn't overly concerned as I just used gas for the limited amount of times we used the van.
After chewing through a few gas bottles I decided that its time to have a look.
First up, I checked the fuses hoping it was an easy fix. No such luck. All fuses were good.
I removed the vents on the side of the van, only to find I didn't really have enough access to see everything so I decided to pull the fridge right out. (as shown in pic)
Removing the fridge involved undoing several screws either side of the fridge door & removing the top switch cover above the fridge door. I also had to undo one screw at the back base of the fridge.
I slid the fridge forward until the gas fittings/ connections (at top of fridge) were accessible. I then undid the gas connection and pulled the fridge right out.
I checked all the wiring and found that no wires has become disconnected. I was hoping that's all it may have been.
While I had the fridge out, I also took the opportunity to turn it upside down and give it a good shake. I found once before (on my old van) that this is good to do if you have a problem starting and running the fridge on gas. Even though I have had no dramas on gas, I thought I'd give it the anyway.
After reading a few forums, I found that the most common reason (apart from loose or disconnected wiring was the element.
As shown in pic, the element is located at the bottom right corner of back of fridge.
It was a simple matter of unclipping the round cylindrical cover and pulling the 240volt element up and out.
I bought a new 240Volt element on ebay for my fridge.
Model number was inside fridge door.
My model number was a Dometic RM2350. Element was $115 genuine domtic 240 V element.
Its easy to tell the 12 volt element from the 240 V as the 240 has three wires including the green earth whereas the 12 Volt element only has the two.
From here, it was just a matter of following the old elements wires and disconnecting them, and re connecting the new wire plugs where I had just disconnected the old ones.
Put it all back together, put it to the test and had a nice icy cold freezer within 3 hours.
Happy Days.
See pics attached.
