Fridge lights from bunnings pls post a link.
3,033
3,405
hi all I ve been to bunnings and there seems to be a mirrod of LED sensor lights. Can someone post up a link to the light there been using so I can simalar.
Yep the first link are the ones we have.... One in the fridge and the other stuck underneath the top bunk so the grandson has some light when sitting in "HIS" little dinette under it!!
Damn it.... They didn't have the black ones when I looked :(
3,033
3,405
Perfect thanks guys.
So you leave on auto? Presuming they must come on and off as you tow and things move in the fridge? Batteries last okay?
megcam
Yep 1 in the fridge and 1 in the toilet/shower to give a bit of light at night when using the toilet. I stuffed the double sided tape/velcro thing so just used some command removable sticky strips on both. Unfortunately I will have to remove them to change the battery but that is future me's problem.
17triton
3,717
5,438
Ballarat
Yep I put the same in fridge and shower. I need to put a dob of silicone on mine to stop the plastic with velcro coming away from the light tho.
3,033
3,405
Geez those clips are 5h1+ ! I got a set for the tool box as well. But couldn't see the clips or Velcro holding so fitted them with two layers of double sided tape. Should allow access to the batteries at a later date?
Marv_mart
1,275
2,019
We use these in our fridge and on suite. Fannnnntastic
Use rechargeable batteries but always seem to last the full trip.
Do find though that the brass/copper connector on the battery compartment lid does need to be adjusted sometimes to ensure a good connection. Take batteries out between trips to ensure no leakage issues. Marv
Marv_mart
1,275
2,019
We put the Velcro straight on the back of the light. The plastic backing plate comes off too easily.
We also turn off when on the move and stow them in a nearby cupboard so they don't fall and break, unlikely though as Velcro very strong. The fridge one stays put for the whole trip but gets stowed sans batteries when van is in storage (see previous post re battery leakage although with modern batteries, that rarely happens)
