Hi @Ssil2000,It’s a thetford n3185 I checked the wire with a multimeter and it’s live
When I unplugged it the front display stopped working so i assumed it had something to do with temp sensor but maybe it’s not?
As for the light there’s 2 little led lights that are outside the fridge bit wierd
As for running it through the drain hose it’s very small I’m a bit worried it’s too skinny I’ll play with it tomorrow
A Thetford N3185 is an AES fridge so it needs a permanent 12V supply to drive its electronic control panel. So it may well have an electronic thermostat and not the basic copper tube thingy.
Hi @Boots in Action,Do any of our Absorption fridges have electronic temperature controls as standard as yet??
So I gather the internal fan should be going when the fridge is switched on.
I have installed a thermostat for the external fan which is powered from the switch on the front of the fridge.
Should the internal fan be wired to the same switched supply but before the thermostat?
Hi @RickB,So I gather the internal fan should be going when the fridge is switched on.
Take note that fans dissipate heat. So, take careful note of the current draw and thus the power dissipation. 100mA at 14V is 1.4W burning away inside an absorption fridge is probably as much as you would want.
How do I stop the fan when the door is open, micro switch on the door?
Hi @Boots in Action,Not quite as bad as that @mikerezny . If voltage is as high as 14 volts, battery would be in a fully charged condition and if continued to stay at that voltage , it would not be a worry on current draw. As an example, I have 2 fans inside my fridge (see previous postings) and 2 fans in my outside portable 3 way fridge. Total draw at 13 volts comes in at approx 0.75 A. (which are not controlled as yet except by manual switch!!) and the external fans X 2 each draw 0.250 A but are thermo controlled. Should not be too much of a worry for @RickB if he has suitable recharging means. Just had 5 overcast days in the Connondales again, and although total daily use for all electrical usages was as high as 37 ah on some days, my MPPT controller was able to cover this amount on 4 out of the 5 days with at least this amount and I only have the one 120 ah battery. Info taken from data provided by controller.
today i have turned the fan to 2, we will see if this will improve the cooling or not as today will get close to 40 in the shade.
once i finish the test empty i will run the test again under load to see if that will help keep temp down or make it worse..
Hi Drover,
My fridge also has a light so can you tell me how / where the relay is installed?
Thanks.
