$43,500
Full height van with underslung suspension for extra ground clearance and ESC (electronic stability control).
Sleeps up to 8. Queen bed at front, double bed at rear, two fixed bunks plus mattress for dinette table for two small people.
Van has all of the standard features plus additional internal power points and 12volt points, external TV point and external 12volt point.
Includes washing machine, reverse cycle air conditioning, filtered water tap, hot water system, upgraded fridge - 180lt with separate freezer door, 240V / 12V television and aerial. Bunks have 2 drawers under, with an external hatch to access storage area behind drawers. Robe has shelves fitted.
Also has a full annex with additional veranda extension piece, 2 Sunbuster shade walls and floor mat, external picnic table, pole carrier, slide out stainless steel BBQ with front gas bayonette connection (great for roasts), privacy screens front and rear, waterproof bed end fitted on sail track (front bed only, sides zip open to roll up one or all sides for air flow) and a battery has been fitted.
Van also comes with hoses and pipes, electrical leads, amphibian (10amp to 15amp converter), towels, bed linen, doonas, plates, cutlery, utensils, toaster, kettle and clothes line, wheel chocs, ramps, additional jockey wheel with ratchet and much more. All you need to do is pack your food and clothes and off you go.
Also comes with caravan cover.
Van is in excellent condition, registered until 11/2015.
Tare: 2105kg
ATM: 2580kg
Located in Montmorency, Victoria
Please call Kim 0409508055
Photos on gumtree http://www.gumtree.com.au/s-ad/mont...-57-9-with-bunks-and-toilet-shower/1084953134
Tare: 2105kg
ATM: 2580kg
