F45s Privacy Room Annexe 3m (large)
In as new condition, only used once.
Size - 300cm long and large height (for awnings fitted at a height of 251-280cm)
With this privacy room you can transform your F45s awning into a comfortable living area
Designed to fit the Fiamma F45s awning
The side panels are quickly put together with the exclusive and patented Clip System S that combines the awning fabric with the sides
No other fixing system is as stable as the Fiamma Clip system S.
A protective sponge is fitted vertically on the back part of the side panels along the support pole to guarantee a close fit
The front panel is inserted in the front rail of the awning and is then joined to the side panels with zips
Both sides come with Fiamma's patented crystal windows and mosquito net.
Located in the Queanbeyan/Canberra area. Can organise freight at buyers expense.
$1000.
- Front panel
- 2 side panels
- Door panel (can be fitted left or right)
- Clip System S
- Support poles
- Curtain kit
- Storage bag
$1000.
