Not a stupid question DS. When I first got my OB I couldn't get the ext shower to work. Rang Jayco. Polite service guy said, try pushing the white button in! Doooh! Felt silly but no one at handover told me. Not good pressure on mine but enough to wash sand off.sorry if it seems stupid to ask, but the button on the shower head is on isn't it?
nah .... if your on mains it supplies everything the pump does. maybe if you have poor pressure it may pay to look at the fittings we did get a run of bad elbow connectors that were moulded bad, only had a small hole in them, took some head scratching to find that.I had poor water pressure in our Swan and the new Expanda also has poor water pressure in the outdoor shower. The internal shower has great pressure. Do you need the water pump on for the outdoor shower even when connected to mains?
I will check out the fittings for the outdoor shower when i get a chance, cheers DaveSnah .... if your on mains it supplies everything the pump does. maybe if you have poor pressure it may pay to look at the fittings we did get a run of bad elbow connectors that were moulded bad, only had a small hole in them, took some head scratching to find that.
under the van it's usually pretty close to the filler, it's a largeish brass fitting about 50mm at it's widest and about 100-120mm long, never remove it from the system tho as the fittings can fail on high pressureI get ordinary pressure in the van when on mains, where do I find the pressure reducer?
Our outdoor shower was the same, absolutely useless - could not even use it to wash sand off my feet.
I took it apart this week-end and this is what I found:
This is where the shower head screws onto the hose. How on earth do they expect any sort of water pressure to make it's way through those pin holes? I used a flat blade screwdriver and popped the restrictor out, put it back together and it now works like a proper shower. I also did the same to the internal shower as well. It does mean that we will use a bit more water, but at least there is decent pressure there now. Really only a problem if free camping and water is on a budget though.
Hope this helps someone.
Thanks for the tip. Still works in 2017. Found mine restricted as well. Now to check the internal shower.Our outdoor shower was the same, absolutely useless - could not even use it to wash sand off my feet.
