Drifter Control Panel - Water Levels
mccrlc
97
88
Tasmania
Afternoon All,
Hoping this hasn't been covered elsewhere (I have searched).
I've never had any issue with the drifter control panel, but ever since the van has been parked up for the winter the 2 tank levels have stopped reading, all other display/functions seem to be ok except those.
Usually if they are empty the bottom bar on the read out flashes, but nothing is happening.
Tried a few simple test, pump on/off, tanks empty/full, ran water through the whole system but still no readout..
Checked the wiring, nothing obvious there.
Maybe a master reset needed?
Any suggestions appreciated.
Marco
mccrlc
97
88
Tasmania
Morning @mfexpanda,
Disconnecting from the battery didn't work, it reset everything else on the panel except the water tank levels.
Do you have any other suggestions please.
Anyone?
ShaneT
291
308
W.A
The drifter is a pain in the ass, mine plays up also. If you download the manual it tells you how to turn each tank display on or off, see if that works for you.
Reactions: mccrlc
