17' Series Crack in shower wall
GlenH
Cowra
Hi everyone, I have a 2013 outback 17.56.2 with a cracked shower wall for the last 2 years and hasn’t got any worse. Does anyone have a photo of any repairs or explain how they did it. Only thing I can think of is plastic welding or applying silicone. Thanks
766
Seems like nobody wants to answer. If I had to repair rather than replace I would probably get some brushed aluminum strip to match the door frame (or gloss white) and wide enough to cover the crack. Then glue the strip parallel with the tiles on all 3 shower wall sides with silicon so it looks like a feature rail.
But firstly I would ask around the caravan repair shops to see if one will get jayco to cover under warranty
Reactions: mfexpanda
2,651
3,817
Id get someone to gut it out strip the bathroom bare replace with aluecomp much better easy to clean never crack
If your in melb ring Advantage caravan repaires they will do it
