Caravan Council Wants to Know Your Weight
2,652
3,819
very nice work I will be contacting these people as my van has a dodgy plate thanks heaps @coled1970 I should have got in touch with them before this but didn't think or know I could
Reactions: crackacoldie
I measured my empty ball weight (crudely with a bathroom scale) when I started to fit the tool box on the draw bar. I didn't do it straight from the dealer, but if I made some concessions it would be pretty close I suspect to the stamped weight. The stamped weight was (IMO) dangerously low ... I presume because we ditched the slideout lounge; lifting a substantial weight off the front on the van. The standard model with the slideout lounge had significantly heavier empty ball weight ... so in my case it appears Jayco must has actually weighed it to obtain the stamped weights
Id be interested to know where Jayco fit on that CCA list
coled1970
374
308
Hunter Valley, Newcastle
Will probably get ours put over the weigh bridge, did it quickly when purchased and it was right on the limit for loaded but had water in tanks so looks like its time to empty van an quick trip to the weigh bridge. Will also be letting know about our wheel issue, have had new compliance plate issued for new rims and asked for ball weight to be increased, got 7 kilo's extra. Its about time somebody started to regulate the industry and keep check on whats happening.
2,652
3,819
Well said I would go them a row of shite houses if I could afford a lawyer
20,088
Well it's about time but without name and shame nothing will happen, not that that should be reason to not do it.
I am tempted to get a tare on mine but thats a hell of a lot of work to get it to that state, dumping water, easy, pull out gas bottles, a bit harder, empty out the inside of van and boot, yikes...................hate to think what the gross is though.
