Have just returned from our first trip in the 2011 Sterling - Perth to Carnarvon via the coast and then back inland for the wildflowers. Yes, we are very happy with the van even though there were a few issues we found & are now fixing.
Updates done prior to trip...
- Have installed a separate battery charger and is hooked up to the van batteries and also the breakaway battery.
- Installed my solenoid tank selectors - saves climbing under the van to switch them over.
- 2000w inverter
- Generator box on back bumper
- MPPT
- Diesel Heater
- Plan to put in 2 grey water tanks (1 for the sink and another for the ensuite) as there is quite a distance between then 2 areas. The sterling has about 350mm between the floor cross members, so this restricts which tank to use.
- Will also install a thermostatic hot water divert er (Redwater) - it diverts the cold water back to the tank until the water is hot enough ( ~40c) as this will save a lot of water when we are free camping.
- Waiting for a solar panel to arrive to be installed on the roof.
