"Big Eddie" build-up
Bugeye
36
36
Northside Sydney
Our old van was 'Eddie' the outback Eagle so this one is naturally ... Big Eddie
Thought I would start a thread to document changes as we go....
Day 1 on way home from pick up at Maccas carpark south Goulburn for lunch
http://www.expandasdownunder.com/showthread.php/2059-Almost-wait-over?p=24522&viewfull=1#post24522
... and 3 days later this is what my wife found when she came out to see what I was doing
I'm not impressed with the guage wire used for battery connections but otherwise it seems tight and well crimped ... which the eagle wasnt!
Should sort all this out this w/e ... as I dont want the setec charging my batteries at all.
Brad
2,645
723
Rowville, Victoria
Yep, my van has looked like that a few times also....
So why not connecting battery to setec unit? What charges your batteries?
Bugeye
36
36
Northside Sydney
Gday Brad
I like to have solar (390w) via a good regulator (sunsaver duo) charge the batteries independently of each other and the setec. I only use the setec to distribute 12v from the batteries when camping or from 240v transformed down when plugged in. On the very rare occasion I get 5-6+ days of poor solar I will charge each battery seperately with a ctek 25amp charger and a Honda gennie.
Reactions: blacky
Bugeye
36
36
Northside Sydney
Electrics coming together now...
Battery switch so I can choose which to draw from...
2nd battery and suresine inverter in place.. with silver/grey ppoint for inverter 240v
Sunsaver Duo managing the solar charge to batteries independently...
Remote meter for Duo mounted next to door for easy looking!
Panel mounted (1 of 2) with anderson block to connect them.
Looks like it grew there from front on....
Bugeye
36
36
Northside Sydney
Zero... they were on with button spot velcro so it was no problem.
Pace... glued two lengths of Meranti together (now about 45mm thick) with wood glue (chose Meranti for weight and colour) clamped together for 48hrs
...cut to shape so it was a tight fit and weight would be down on benchtop
...used marine varnish for gloss and protection
...use sika glue/sealer all over back which went against wall
...2 x 50mm wood screws from side of top cupboard into Meranti
...8 x 50mm wood screws hold swing arm base onto Meranti
It is so solid the whole van shakes on its suspension when you try and move it!
Reactions: blacky
Bugeye
36
36
Northside Sydney
Just got my new rear bar fitted up!! ... Fabricated by @Burnsy and then I sprayed it, added tread plate to protect from chips and fitted it.
Top workmanship by someone who knows how to do metal!! really pleased... photos below ... now just the box for A-Frame to get...
Good to deal with ... done to a price as promised. No affiltiation just a pleased customer! :)
Wow @Bugeye, that came up great with the silver paint, love the idea of the alloy tread plate too....well done! Thanks for the kind words.....glad your happy! :)
Reactions: blacky
