Suspension Bearing Numbers and Dimensions
this contains a list of all the bearings and seals used in trailer axles as well as the dimensions.
I have attached the original pdf from alltrailerspares as well as an image of it that I created.
  • bearing numbers.pdf
19,906
Very nicely done, you have far too much time on your hands ................................... I will print that out and staple it up in my shed.
Should add the numbers are international standard, not brand specific usually
Parallel Bearings don't have a Big inner, Small outer, they are both the same bearing......
