Hi there,
We've just purchased an older 2005 12ft Expanda. It is set up with Solar & 2 batteries and a 1000w Projecta Power Inverter.
I've towed it home from Vic to NSW only to discover - having just had an auto electrician in Vic (near my family) tidy things up & replace a wet battery (that the previous owner had installed) with a dry battery - that the batteries are flat or not working. It almost seems like the whole system isn't working. I've run the basic fuse & circuit tests & all OK & it seems the batteries have about 6V in them. The Inverter is sending out it's alarm signal & showing the red fault line. I understand that this can be from too little charge among other things. Sadly I'm now 10hrs from the auto-elec who did the work so, having just shelled out $600 for the electrical tidy up & new battery, I'm wondering if there's anything obvious I'm missing before arranging to get the van to a local auto-elec & yet more $$.
The Van is set up with solar (solar panel about 3x3 ft) & the solar charge controller Panel is completely dead/blank not showing any LCD screen/reading (Solar 30). Also the battery LCD display is dead - not lit up or showing anything on screen. I've come home - parked the van in the garage so no sun for the solar - & plugged the van into 240V & turned the battery switch on. It's now been on for 24hrs but the batteries haven't charged at all & all the displays are still dead. I'm wondering if the previous owners would've disconnected the 240v charge when they set the solar up? The solar is set up to charge the batteries while driving. I did turn the fridge on for the drive (it never seemed to cool down at all) so not sure if the combination of the fridge on (10hr drive home with approx 50% sunshine during trip) and lower sun levels would've drained the batteries? Regardless, I would've thought the solar 30 display panel would've stayed on & showing what was happening with charge - even if no charge I would've hoped the display shows zero charge coming in? Similarly, even if the batteries are low (I ran a meter over them & they're putting out 6V) I would've expected the battery LCD display to be giving me some kind of reading?
Any thoughts from anyone would be soooo very welcome. I feel like something's amiss & perhaps I'm missing a switch?
Thanks!
Benita.
Thanks!
Benita.
