The old set up of mine back in the analog days, once the cranker was juiced up it was full noise to the aux, unless the big spotties were running then it was take whats left over which wasn't very much.......... now with smart chargers and there are a few varieties, any extra stuff the ground must be to the engine/body where the cranker connects and not on the cranker battery it self or all sorts of drama happens, a quick look at the NEG post on the cranker usually shows a box of some sort on the post or on the cable run, this is where the ECU monitors the battery so any connection must not be fitted between it and the battery............... Found this out when my mates Ranger years ago, wired up by the Dealer for an aux from new, wrecked 2 batteries in short order, something on this site reminded me so we rewired it and now years later its still working and the dealer said BS, we proved him wrong..... Well thats what I have found works with Rangers, BT50's the Jeeperific doesn't seem to be problematic ..............
I think you will find
@poor but proud that all will be well in the long run........................... but alternators while everyone see's 70 or 80 amp capacity, old style would only throw that amount once the revs are high enough, at idle it can easily be half or less which is why batteries can take time and today electric everything and with electric steering it can eat nearly all of that with an ECU governing output using battery state, load and ambient temp to configure a charge rate ...........
