Not sure what my plug is going to be. In the package I am getting a battery and solar pannel included, I'm really not sure how everything works in terms of power.....If you are getting a 12 pin plug, can't think why you would need one as you will have spare pins. I used to have an extension cord with heavy wiring and plug my car in about 5 mins twice daily (usually while I was coordinating kids in car etc, unloading fishing/beach equipment) and that along with a small (very small) solar panel was enough to keep my caravan battery charged for in excess of a fortnight. Also small changes like reducing halogen wattage (although now 2013 models are LED) so this wouldn't matter.
What would the cost/weight benefit of an extra caravan battery vs investing in decent solar panel maybe - just more food for thought?
Sorry Swift, I did mean 2 batteries in the camper. Im not sure how it all works and I only have one battery in the car. Im confused and sure how it all works with the power or how long batteries last. I just dont want to drain my car battery. How long do the batteries in the van last?Les, sorry I thought you meant 2 batteries for camper - definitely get one If you're not sure about a second one, you could ask Jayco if they will just set up wiring, so you have the option to connect or not.
Hi Stan your Swift should run on 12v whilst travelling or gas if not connected to 240v as it is 3 way - not sure why the need to keep it on 240v. Not sure if yours is the same, but Jayco told me mine would be able to charge battery via the live wire pin that would supply 12v to van when connected to car pin 2 on 12pin plug (I hope it is heavy enough wiring not to get voltage drop for battery charging).
No no anderson plug on the terri. I was thinking I could plug in a portable solar pannel to help the one thats fixed in place. Sorry to confuse everyone, but I have very little knowledge of the electrical side of things and its our first van.Hi Les
Jayco usually stick with the 7 pin plug if you have the 90ltr fridge and move to the 12pin if you have a larger fridge. This setup works ok for most people. If you are a heavy power user or intend doing a lot of remote area travel then you may want to consider an anderson plug. If your terri already has an anderson plug then yes i would get an anderson on the van to match.
I have a feeling the 2013's are all 12 pin
I have a feeling the 2013's are all 12 pin is that right? My cousins 2013 OB Swan came with a 12 pin and no big fridge, he was told that they are all 12 pin but that maybe only relates to campers.
For us we had the anderson wiring done when we ordered our Expanda.
