Hi all,
Long time caravan lover, short time member, first time poster.
I have a 2016 18.58-2 Pop Top Expanda Outback with the Thetford N3185 174 L Fridge.
We bought it back at the start of March 2020, and, thanks to Covid, have barely used it.
On the few trips we have managed to take it further than the front gate, I've become aware that the fridge will only last approx. 20 mins, then will start to flash battery.
We have dual 110AH AGM, and van is connected to car via 12 pin plug. Tug is 2019 Ford Everest Trend 2L Bi Turbo.
We are now planning a larger 2 month trip through central Aus, so I need to get this sorted ASAP.
What I'm wanting to know is if my planned setup will work to keep the fridge running at all times:
1) Run a new Anderson plug kit from battery to back of car. Kit will come from battery and be fused under bonnet. Still looking at if I need a relay or not.
2) Connect 8AWG cable at base of fridge where cables are currently feeding fridge(access via hatch on outside of van)
3) Run 8AWG wires through box chassis, following existing cables, bring out of grommet near hitch.
4) Fit off Anderson plug to this cable, ready for connection to tow car.
My limited understanding is that this will keep the fridge running off the tug battery while alternator is running, meaning the fridge should run whenever driving.
Can one of you smarter people please confirm this will work, or let me know where I need to run?
Alternatively, I'm open to other suggestions.
Should I run Anderson plug to battery charger in van?
Thanks in advance for your help.
Kano.
Kano.
