I have a Honda 2kva, can anyone tell me if this little gen will run the ibis AC? What power does the ibis require?
Hi mate, welcome to the forum. I have the same and it does run the ibis roof top, best not to leave it in direct sunlight when running high draw appliances, this may cause overload from heat.
Hi Burnsy
Can you run the ibis in heating mode with the honda 2kw?
Havent tried that to be honest, doesn't the ibis draw less for heating? I'd have to look at specs. If its not flogging down rain here on weekend I'll try it for you!
Thanks for that Burnsey very generous,
the specs I saw for the ibis were cooling 2.8KW, heating 3KW
By the way way can you run the aircon flat out with the Honda 2kw?
We have just signed the contract for the 18.57-6 OB ( with ibis) therefore the generator queries. Have been researching quite a few different portable genies but haven't been able to find a better all round package than the honda 2kw, only concern is will it be able to cope with the ibis at higher run settings
Don't get your kW & kVA mixed up they are two different measurements.
pretty sure they were KW ratings CJ
Sorry mate, didn't get the chance this weekend.....wet all weekend , i'll try as soon as i can!
Hi Burnsey,Sorry mate, didn't get the chance this weekend.....wet all weekend , i'll try as soon as i can!
Really sorry mate, I forgot all about it......I'll try this week.Hi Burnsey,
Did you get a chance to give the Ibis a run with the honda gennie?
I think the issue will come on in the heat when you want it most. 40 is enough to make most stationary motors very hot.Hi there @xpanda, I got the Honda eu20 out this afternoon and ran the Ibis aircon for 30 min on cool with fan on high and it coped no worries. Ambient temp at the time would of been mid to high 20's. Sorry still haven't tried it on heat yet!
