I have noted some excellent electrical mods.. but nothing that seems to touch on my issue. I am adding an 80W portable panel and need to wire in a method to plug it into the van to charge my 105Ah AGM. One of the threads mentions cutting off the solar panel alligator clamps and terminating to a flat trailer plug and connecting the panel into via that method. My concern is the voltage drop.
What I am considering is:
removing the solar reg and placing closer to the battery. This I am told is best as allows temp cut out and no/less voltage drop ?
terminating the panel cables to a male cigarette plug.
then plugging in the the solar to the pre existing, externally mounted 12 volt socket labelled as external shower.
will this work ?
My van is a 2005 12ft expanda.
will this work ?
