^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^THIS COULD BE YOU^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
"GLAMPING" AT IT'S FINEST!
This fastidiously maintained and very well presented Jayco 17.56.1 Expanda Outback will take you just about anywhere. Unfortunately we need to make a change, so our loss is your gain. All the hard work has been done.
Storage is abundant as we have converted the closets to a drawer and basket system and added many little storage features throughout the van.
Located in Adelaide
The van comes with all the standard outback features plus MANY more:
TV mounts inside and out ( Quick release and all wired )
TV Antenna
LED lighting inside and out
Extra 12 volt USB and lighter points
12volt water pump
Privacy screens for both bed ends
Carefree Awning with de flappers, ropes and pegs
Full annex with optional privacy screen
Full skirt
Dual 110 amp batteries and Redarc charging. (solar compatible)
Battery monitoring
Anderson plug with heavy duty cabling
Full under body protection of all gas and plumbing lines
Full dust-proofing where the body meets the chassis
4 .... yes.....4 pole carriers
Storage on the A Frame that suits a Weber Q200.
Drawer system and wire shelving installed in both closets. (Hanging rails supplied also)
The stone guard in the pictures will also be supplied to protect both the van and your car
Water tap on A frame
Water hoses included
Convection Microwave
All manuals included
Alko drop down jacks
Quick release jockey wheel
Prestige caravan cover
More details: http://www.gumtree.com.au/s-ad/flagstaff-hill/caravan/jayco-expanda-17-56-1-outback/1070011861
We have set it up with free camping in mind, with 2 x 110 amp AGM batteries and a Redarc BCDC1240 charging system, heavy duty cabling throughout, LED lighting and a low power consuming water pump.
Our home away from home has always been stored under-cover with the cover on.
$40,000 ONO
A true family van that can go anywhere and give you comfort, style and easy set-up of "Glamping"
