17' Series 17.56-2 mods.
Mattd
12
11
Hi there,
Thanks for the valuable information gained.
A few questions.
1. Did the 2013 outback model 17.56-2 come standard with the simplicity suspension or leaf only? If leaf only, any good?
2. Can outdoor speakers be retro fitted?
3. Difficult to swap over standard ball hitch to ozhitch?
4. Do outback models with battery and solar have an anderson plug fitted as standard?
5. Retro fitting of outdoor tables. Easy work?
6. Outside entertainment pack. Can this be retro fitted?
Thanks again. Matt
Hi @Mattd ... I'll try my best but certain others will confirm things if I can't!
1. Leaf only. All I can say is they have been around for as long as I can remember ;) Simplicity would be better if going offroad often.
2. Yes if you are handy... Just have to make sure you pick the right spot to fit them.
3. Not 100% sure but if the bolt hole centres are the same (or close) shouldn't be an issue.
4. No. Have to be fitted aftermarket if not done during the build.
5. Refer No.2 above but location is up to you.
6. No idea but don't see why not?
