16:49-3 wheel bearing numbers listed
3,033
3,405
For anybodies information whilst cleaning up I found the p/n's of the wheel bearings from our MY07 16:49-3 expanda.
they were
Outer 15123 1.1/4” ID
Inner X30210M 50mm ID
not sure if Jayco still use the same or what they are off. I remember measuring them at the time (with verniers) and can confirm the ID's of the inner was metric nominal and the outer imperial nominal which is a bit odd i think.
hornet
62
We're these off an out back jim on onroad? Mines an 2007 16/49/3 ob , ive got the numbers for the bearings, but struggling with numbers for the outer race, apperently there is three different od's for the outer race, like you said metric bearing but there's imp and metric outer races , without smacking the outers out of the hub I can't get the numbers, anyone else got any numbers , I believe the ob axles are bigger?
