Mel, I have private messaged you with some details. Here is the info from the web.
Internal features
Toilet and shower
› Aluminium LP corner extrusion & aluminium seat frames› Dometic RM2350 3 way fridge in Pop top, SMEV 4 burner gas griller with one 240v element, 12v ignition & flame failure device› 12v power system with built in “Trickle” charger› Queen size parents bed› 12v lighting system including bed lights› Microwave› 12v rangehood› Flush fitting stainless steel sinkwith cover› Flush fitting stainless steel sink with cover› Curtains to bed ends› Designer Pelmets› Positive cupboard catches › Moulded Step Insert› Zippered cushion covers(vinyl backed)› Rubber backed curtains & ties › Overhead cupboard stays(where possible)› Mains pressure tap to sink› Pot drawers under griller› Scrim curtains (weighted)› Coaxial TV poinAir conditioning
External features
› Jayco Tough frame› Solid fibreglass roof over bed ends› Galvanised “Millennium Chassis”› One piece jumbo boot liner› LED external running lights› Alloy wheels› Concealed windout windows› Bumper bar› 2 corner Tri-lock Trimatic security door› Sandwich domed seamless F/Glass roof› Aluminium body & roof top frame› Aluminium body & roof top frame › Removable fly screen windowsto pop top tent› Grab handle & light at door› 240v / Gas HWS › 2x 82 litre water tanks onshoLockable water 12v annexe light› 240v external power point › External mains pressure, Roll out Awning, Deluxe bed privacy screens.
The Setec power converter is Australian-designed and constructed for our country’s occasionally inconsistent supply of power in remote areas. This built-in fused power converter provides a safe 12v supply from 240v mains. Produced specifically for Jayco, the Setec system delivers generous lighting on either 240v or 12v supply.When only 12v power is available, the unit is self-sensing and no switching is required. A valuable additional feature of the unit is its built-in trickle charger (13.5v output) to cater for an auxiliary battery.
