Yep, the 5min anode change turned into a 3 hour project as the new anode thread would not bite no matter how many times I tried.  Ended up removing the gas jet/ tube and overflow pipe to get a decent look as the replacement is identical to the one that came out and would screw in easily.....ghaaa
Anyway I cleaned the threads in the hws, filed the thread on the new anode, wrapped and re wrapped the tape. Finally tried a shallow socket that would push hard on the end, rotated it in reverse several times....and finally success. At least it got a good clean in the process.
