Picking up my 14.44-4 this weekend and was just wondering if any of you have any tips for things to check at delivery. Moto Moto I know you got your 14 a week or two ago have you found anything of concern?
G'day Boots, I hope all goes well with your pick-up. Things that were wrong with ours at pick-up and since :-
1. Air con did not work. I would have had to wait another day to pick up so I arranged to bring it home and get fixed locally. Done.
2. Front boot leaked (badly), Two attempts to fix finally resulted in rubber strip above boot being removed and resealed. Done
3. Double power point in slide out pantry where microwave and oven connected, only working on one side. Not yet fixed
4. Bed hard lid latch not holding on one side. Not yet fixed
5. Seal on bed lid coming off on one corner. Done
6. Cracks in fibreglass roof. Not yet fixed
7. Tow hitch too low. Fixed at my expense with 2 x 25mm blocks.
8. Clearance light at front top full of moisture. Replaced
Still happy with the van and Jayco's backup. :yo:
Paul
Interested in number 7, I thought there hitches were at the ADR height?
We didn't get LED lamps in ours either so I have just ordered 4 from China for $7.72 delivered and will fit them when they arrive.
Paul
G'day again Shane. Yes, the ones not fixed are because I have not had it back to get them done. They will be fairly simple fixes except for the fibreglass repairs but this one is in hand and hopefully will be done shortly. ound:
Hi, Jim. The tow ball receiver welded to the bottom of the of the draw bar is fine if towed with a normal car or wagon but I have a 4WD which is higher to start with and I want to get a suspension upgrade which will raise it even more. This then lifts the front of the van and dropping the rear end which, on an Outback, is not a welcome outcome. At the moment, with the 50mm lift in receiver, the van rides level. But I see in Stone Stomper's pix he has welded the hitch to the top of the draw bar. I don't know the legalities of doing this but it would sure sort out my situation. :wink:
At the Sydney show every pop top i looked in had the new LED lights. I asked my dealer if they were standard and he said yes on all 2011 models except campers.
He showed me some floor stock, some that came a few weeks before mine was delivered had LED's, all the van that came in the same delivery as mine had the old school lights. He figured they probably ran out of stock to just used the older ones. He changed all the globes over to LED no problems at all. Over $200 worth of LED's!!!!!!!!!
Worth asking the question!
Also worth asking about payload. As far as i understand they always have 300kg on expandas, but if you ask, depending on the model, sometimes you can get more:rockon:
My dealer said that quite a few owners who got the factory fitted LED's came back to get them swapped with the older style light fitting but with LED replacement globes. The main reason was the switches were a bit fiddly on the new fittings.
